Your search did not match any results.
We suggest you try the following to help find what you’re looking for:
Enhance your developer skills with our technical, educational and interactive virtual events.
Auto-Indexing Deep Dive
Learn some Auto-Indexing best practices and how to monitor the dynamic changes made over time.
Build Cloud Native Applications on Oracle Cloud Infrastructure
Learn how you can build and deploy a microservice-based application on Oracle Cloud Infrastructure using Oracle Cloud Infrastructure Container Engine for Kubernetes (OKE).
Autonomous Database vs. Classic
Learn about Oracle's Database Services as we compare use cases for Autonomous Database vs. Classic and demonstrate how to provision each.
Message Driven Microservices & Monoliths with Micronaut
Learn how to get started implementing messaging in your applications using open source tools such as Apache Kafka and RabbitMQ, as well as a managed Oracle Cloud-based option that can be plugged into your service with very little setup and configuration.
Developing Serverless Applications on Oracle Cloud Infrastructure
Learn how easy it is to build and deploy a serverless applications on Oracle Cloud Infrastructure.
Application Continuity for Developers
Application Continuity hides interruptions from applications and users. Learn how application developers and owners can easily take advantage of this functionality to add this resiliency transparently to the user experience without making changes to the application code.
Oracle Developer Live - Java Innovations
Learn how Java can help you create the next generation of rich, scalable, secure, and modern applications for a variety of targeted deployment environments. Gain insight into innovations within the Java 16 release that improve the performance, stability, and security of application development.
Microservices Distributed Tracing: from traces to operational insights
Learn how to implement Opentracing in your microservices deployment, how to extend the coverage to older legacy java components, and how to use the trace data for diagnostics, monitoring, planning and reporting.
Best practices in designing JSON document model in Autonomous JSON Database
This session focuses on JSON design, modeling questions and best practices to support your application development. We will share our top 10 tips for processing JSON in a database and give a live demonstration of Autonomous JSON Database Cloud Service.
Build Applications Faster with Low-Code
Learn about the latest APEX offerings. Discover how customers and partners like MineSense and Insum are succeeding with APEX. Join a Hands-on Lab to convert a spreadsheet into a multi-user Web application in minutes. Listen to what Forrester has to say about emerging Low-Code Industry
Oracle Developer Live - AI and ML for Your Enterprise
Put AI to work for your business and IT operations. AI can accelerate automation, reduce human errors, and enhance business insights. Join Oracle executives and product experts as they discuss how to eliminate the development roadblocks to building an AI-powered enterprise. Because data is the foundation for AI, you'll also learn how to access, prepare, and process it with speed and agility.
Oracle Developer Live - Cloud Native
Engage with experts to learn how you can build open, cloud native technologies into your stack to gain speed and agility without compromising security and reliability.
Developer Live - MySQL
MySQL is the world’s leading open source database. During Oracle Developer Live—Oracle MySQL, developers had the opportunity to learn about the latest developments in MySQL 8.0 directly from the MySQL engineering team.
Learn about Java 15 and how to improve your Java skills to address modern application development
Developer Live - Database
Learn how to harness the power of Oracle Database to build data-driven applications
Why developers choose NoSQL Database for application development?
Learn the technical drivers and business rationale for choosing to use NoSQL technology, use cases and deployment patterns developers use when choosing NoSQL technology, and design tradeoffs commonly made by app developers in choosing between relational and non-relational data stores
Visual Builder - New Features for February 2021
The February version of Visual Builder will offer many new features. In this session, we'll review the key features in the areas of coding environment, services and backends, Git integration, and more.
Real-world Low Code: Four partners show how they deliver solutions using Oracle APEX!
In this special edition of APEX Office Hours, we will be joined by four different Oracle partners who will share real-world solutions they've developed using Oracle APEX, across numerous industries and use cases. It's a great opportunity to see what is possible with low code and APEX, and also understand why these professional developers choose APEX.
Incorporating DevSecOps into Oracle Container Engine for Kubernetes with Check Point's CloudGuard
This webinar will present options using Terraform and Helm for integrating Check Point's CloudGuard Posture Management for Kubernetes in OKE and deployment of Check Point's CloudGuard AppSec protection for Kubernetes applications.
Storage Services
Learn how Oracle Cloud Storage delivers consistent high performance and scalability. We’ll introduce local, object, file, block and archive storage services and address key storage workload requirements and use cases.
Creating an App based on Existing Tables for Oracle Autonomous Cloud Service
This workshop walks you through creating an APEX application based on existing tables in your Oracle Database. You will build the first cut of an app based on existing table, reload an app and regenerate, add and link pages, manipulate regions and items, and define client-side interactivity declaratively.
How Autonomous Database accelerates developer productivity
A kick-off of a new monthly Autonomous Database deep dive developer series. The series will be dedicated to technical deep dive on how to use specific autonomous database capabilities, each month covering a different feature. This kick-off webcast will give an overview of the latest autonomous database capabilities with a snapshot of the features we will be covering in deep dive sessions in the coming months. We will cover the ways in which Autonomous Database automates developer activities, streamlines development of critical business applications, review autonomous features and review of the developer facing tools and 3rd party integrations with IDE's, SDKs, orchestration technology.
Explore the converged functionality of Oracle Autonomous Database
Explore Oracle's converged Autonomous Database, a multi-model, multitenant, multi-workload database. In this hands on workshop, you'll learn ways to consolidate and isolate a shared data model across multiple development teams and using all workload.
Terraforming the Cloud with Oracle Cloud Infrastructure Resource Manager
Learn how to script a web application with Terraform and use Resource Manager to deploy to Oracle Cloud Infrastructure (OCI). Join this webcast to discover practical, in-the-field techniques of infra as a code. We demonstrate how to use best practices methodologies of automation while introducing the Oracle Cloud Infrastructure Resource Manager framework for using Terraform on OCI to codify infrastructure.
Build a Fully Functional APEX App from a Spreadsheet in 45 minutes!
Get your feet wet learning how the new APEX as a Service works to build a fully functional APEX app in less than an hour. In this lab, you'll learn how to create an APEX App from a Spreadsheet and navigate and make changes to the APEX Application
Faster and safer application deployments on Kubernetes with Shipa and Oracle Kubernetes Engine (OKE)
In this webcast we will show you how Shipa and OKE provide developers an application-centric view they need so they never have to think about Kubernetes objects again, allow platform engineers to put up guardrails and centrally control deployments across multiple clusters, monitor application performance, and implement network policies and security configurations from a centralized dashboard and eliminate the need for custom Helm charts, Terraform scripts and YAML, reducing months of work that has to be done before pushing your first application into production.
Cloud Coaching Office Hours: Computing Fundamentals
In this session, learn how to set up Bare Metal, Virtual Machine, and Dedicated Hosts instances and hear about the advanced features and performance OCI compute provides, with a variety of image and shape options.
Visual Builder - What’s New
Learn about the new features added to Oracle Visual Builder in the latest release and how they benefit you. We’ll demonstrate Redwood UI and Oracle JET 9 updates, Improved development experience, and Visual Builder Studio integration for team development and CI/CD. We’ll also discuss what you need to know about upgrades, and the latest learning resources published for developers.
Flows for APEX - Model & run process flows within APEX!
Flows for APEX is an open source solution enabling you to design and run process flows within your APEX application. This was developed by expert members of the Oracle APEX community, and it has quickly evolved into a functionally rich process modeling solution. In this special edition of Oracle APEX Office Hours, we will be joined by the creators of Flows for APEX, where they will present and demonstrate the latest version 5 of Flows for APEX.
Oracle Cloud Coaching: Networking and Connectivity
Learn how to set up a virtual cloud network with firewall rules and communication gateways that you can choose. Highly skilled solution engineers will show you how to define public or private subnets within your VCN, add virtual routers to control traffic flow to outside destinations and secure your cloud network and compute instances.
Accelerate development of data driven applications with Oracle’s Database Tools
Learn how you can load different types of data from multiple sources in a few simple steps using Oracle's free database tools.
What's New in Oracle APEX 20.2 with Printing!
Join APEX development team as they explorer the new printing capabilities in APEX 20.2
Cloud Coaching Office Hours: Identity and Access Management
Learn how to set up consistent identity enforcement and manage employee, partner, and consumer access to cloud resources with Oracle Identity and Access Management.
Accelerate & Simplify Blockchain Application Development
Learn about Oracle’s new developer enhancements designed to reduce the time spent developing and coding blockchain apps.
Spend Less Time Debugging Code with ML-based Log Analytics
Let’s face it. You love to code but debugging pesky problems is always in the way. Join us in this session to learn how to identify business flows that are behaving abnormally and use machine learning techniques, including pattern recognition, trend analysis, cluster compare and links, among others, to quickly troubleshoot code defects and application performance issues.
What's new in APEX 20.2
There are many new features coming in APEX 20.2. In this session, we will present and demonstrate the marquee features of this latest release.
Developer Focus on Converged Database2
Oracle’s Converged Database offers a robust set of application development tools that empower developers to create fully integrated business applications. This webcast will discuss the different ways developers can leverage the wide variety of tools, workloads, data types, analytics and data management functionality supported by Oracle’s Converged Database platform.
Getting Started with JSON Document Collections in the Autonomous JSON Database
Todd Sharp introduces you to the Autonomous JSON Database (AJD). AJD is exciting because it represents the very first time Oracle is offering a dedicated solution for JSON document collection persistence in the Oracle Cloud. It represents Oracle's commitment to offering developers tools and solutions that help them solve the problems they face when developing microservices and applications instead of trying to convince them to use a tool that might not be the best fit for them.
Ingest, Analyze, and Manage Your Logs with OCI Logging
Learn how to use the powerful analytics engine to search and analyze logs, and use the intuitive rules engine to act in near real-time on any log event.
Moving Logs with Oracle Service Connector Hub
Learn how to move logs from the Logging Service to Oracle Cloud Infrastructure services such as Object Storage, Streaming, Monitoring, Functions and Notifications.
RackWare Enables Container Migration to Oracle Cloud Container Engine for Kubernetes
Learn how RackWare Enables Container Migration to the Oracle Kubernetes Engine
Advanced Chatbot Development - the Art of What's Possible
Learn how Oracle Digital Assistant is pushing beyond the wall of what’s possible in enterprise chatbot development.
Location matters! Map Visualization for APEX Developers
Learn everything about the Oracle Maps technology and how to use it in APEX applications.
Carsten Czarski, Consulting Member of Technical Staff
Honglei.x.Zhu, Principal Member of Technical Staff
Getting Started with Serverless Apps on Oracle Cloud Infrastructure
Serverless Computing is now available in the Oracle Cloud. Join us for an overview of Oracle Cloud's Functions-as-a-Service and learn how you can use Oracle Cloud’s serverless building blocks - Functions, Events, and API Gateway - to build modern, event-driven microservices.
Greg Verstraeten, Senior Principal Product Manager
Sachin Pikle, Product Strategy Director
The Top 12 New Features in APEX 20.1 that Everyone Should Know!
Learn what the top 10 features of 20.1 are and how you can enhance your APEX applications.
Joel Kallman, Senior Director, Software Development
Hidden Gems in the Cloud
Learn where to find and how to use these lesser-known features. You’ll be sure to learn a few tips for saving money on your cloud bill, ensuring compliance, manage your database instances, monitor performance and even some tips for writing more efficient code in your applications.
Todd Sharp, Oracle Developer Advocate
Headless CMS: Creating Modern Digital Experience
Learn how to utilize Oracle Content and Experience as an enterprise-grade CMS and intelligent content platform suited to serve a variety of content and architecture needs.
Preston So, Senior Director, Product Strategy
Lee Ribeiro, Product Marketing Manager
Managing Kubernetes Applications on Oracle Cloud with Nirmata
Learn how Nirmata can be used to provision and manage OKE clusters. We will explore how Nirmata addresses Day 2 operations challenges for OKE clusters and discuss how Nirmata simplifies application deployment and management of cloud-native applications.
Ritesh Patel, VP, Product, Nirmata
Gilson Melo, Director of Product Management, Oracle
Optimizing grocery delivery routes using Oracle APEX, Oracle Autonomous Database and Google Maps APIs
Learn how Santhosh Jose, a Principal Applications Engineer in the Oracle HCM product development organization discovered Oracle APEX to solve a specific problem during the Pandemic. He built a RouteBuilder app that optimizes grocery delivery routes.
Santhosh Jose, Principal Applications Engineer
Beginner's Guide to Oracle APEX
You've heard about Oracle APEX, you're keen to learn more and see what it can do.
Anthony Rayner, Principal Member of Technical Staff - APEX Team
Introduction to JavaScript for APEX Developers
Learn how to write essential JavaScript code, add it to APEX apps, and work with jQuery and the DOM.
Dan McGhan, Developer Advocate
Get Hands on Experience Developing in the Oracle Cloud at your own pace. See a list of the hands on workshops using Oracle Cloud services.
Get Hands on Experience Developing with Oracle Database in the Oracle Cloud at your own pace.
Get Hands on Experience Developing Java Applications in the Oracle Cloud at your own pace.
Get Hands on Experience Developing Apps with MySQL Database Service at your own pace.
